Configure Telnet Connection in FRStack
I have version 3.1.35.65 installed and I do not see where to enter Telnet info for the spot function. Under View -> Options -> there is no "Spot" selection. I see only other spot related entries.
What am I missing?
View/Options/Spots
Hi Larry,
Thanks for your reply. Attached is what I see.
OK, I think I see what happened.
I had not uninstalled an older version 2 when I installed the version 3. That appears to have left me with the version 2 menu configuration.
I uninstalled v2 and tried the v3 install again.
Now I see the new tabs under the options selection.
Thanks!
Thats strange, your using the same version i am, your missing a row of tabs in options.
See my previous response.
FRStack V2 and V3 can be installed at the same time. They different install folders and have two different ICON names.
FRStack ICON is V2 and FRStack3 ICON is V3.
Thanks for you reply.
Well, perhaps it was my error. I could have sworn that I closed V2 prior to opening V3.
I had a shortcut on the taskbar for V2. I believe I closed V2 and then opened V3 from the Program Files V3 folder location.
It's water under the bridge now.
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
