2x8 AG with Flex 6700 and FTDX 10
I'm not sure if this is even possible, but I like to be sure before I give up.
I have my Flex 6700 on port 1/A on the AG. LAN controlled and working UFB. I would like to use port 2/B and connect to my back-up FTDX 10. I'd like the Flex to work as it does. But want to control FTDX 10 manually with the AG App.
Have set DIP 3,4 to Off for IG control on port 2/B. Flex works fine on LAN/port 1/A, follows radio. But I can't get the Ap to show manual control on port 2/B.
I have tried to find the answer in the manual, 4O3A videos, Flex community, as well as Googling. I have "experimented" with my settings, just can't make it work.
Do I try to do the impossible? Or what a'm I doing wrong? Help!
Johan, SE3X
Ps. I have asked the same on 4O3A forum without reply so far. In desperation I try here as well.
Adding some information .. I just gave up and closed Flex and SSDR. Then the IG app suddenly shows manual selection for all my antennas. But signal is still on antenna port 1/A and not 2/B.
Latest AG software 3.1.5 and SSDR 3.3.32.
I really would like to be able and have both my Flex and the FTDX 10 attached at the same time and not have to switch of the Flex.
Contact Ranko or Dragisa at 4O3A direct, they are very helpful.
You can raise helpdesk tickets from their website or email them.
V4 for AG is due anytime now, it's a total re-write so might be worth waiting for that as a lot of changes are coming but they might be able to help using the current version too.
Rich
Well, I have asked in their forum, no success so far. Just curious if any one reading here had tried, or made it work. I have been thinking about one thing to try in the configuration. Will try that even if my hope are slim ;) Otherwise I might send Ranko an e-mail.
Anyway Rich, Tnx for your answer.
Done some more reading as well as experimentation. It seems like one need to have their 4O3A Station Genius box to do what i want. I do hope someone here knows more about it. Or that I will get a reply from 4O3A direct.
So, still interested if anyone here know more. Any info appreciated.
Hi Johan
Try this. Set dip switches 3&4 for BCD control. In the antenna configuration in addition to selecting the band or bands for each antenna port, also select None for each port you want available for the FTdx10. Then select Save to reboot the AG.
Hi Dave,
Yes this was one of the first things I tried. No difference, doesn't work. If I switch of the Flex the Ap show manual selections. But as soon as I have Flex broadcasting network data, it's all back to it taking over. Doesn't matter if I have one or two Panadapters open.
Thank you Dave, but I more and more lean towards that one would need the Station Genious box to achive what I want.
Johan, SE3X
Are you sure in the Configure Flex Radios tab you don't have Antenna Genius active for port B by mistake? That would cause the Flex to take over when the radio and a client are connected.
I just tested here with all 4 dip switches set to LAN.
I unchecked Active for Port B in Configure Flex Radio tab in AG app
Then in Configure Device tab click to the right of each antenna name. Click Save & Reboot.
Then make sure to select None for each antenna port in addition to bands that antenna will be used for.
Click Save then click Save & Reboot.
One note - I am using AG firmware 3.1.5 downloaded from 4O3A site
Hi Dave,
Sorry for late reply, we have a bit of time difference between us. I have tried exactly what you describes without success. But just to make sure I will try again today. Yes I have AG latest software: 3.1.5 from their site.
One thing I'm wondering about is that in a early You Tube clip they show configuration of AG. It starts with a selection Slice A, Slice B or SO2R. I can't find that setting, when I configured my AG I probably choose SO2R if asked. I have been running my 6700 in SO2R mode. I have done a full reset and this alternative never showed up. Perhaps in a earlier version of the AG software. Could this setting been the reason why it doesn't "forget" about activating both slices as active? Very long shot, but hey it's a computer software thing ..
I will do a factory reset of the AG today, to really start from scratch, and then try settings you suggested.
73, Johan
Hi Johan,
If you had selected Auto Connect in AG app it will connect to the mode you last used. If you are seeing both A and B in AG main screen but B is greyed out then the AG is still configured for Flex on port B.
Ok Dave
not at home tonight, visiting friends all day. Didn't have the time to try before I left earlier. But I will try tomorrow. Tnx for the idea about auto connect as well.
I will report back as soon as I have tried.
73, Johan
@David Decoons, wo2x Thank you so much for great support Dave! Sometimes it's those small details that makes it :) In this case your remark "If you had selected Auto Connect in AG app it will connect to the mode you last used." that solved it.
As soon as I closed the Ap and manually restarted it everything came up just the way I want it ..
Today not using more than 5 ports. Work in progress: new 160m vertical, fixed 3-band Yagi (10,15,20m) @ US and finally my new homebrew 4-el LFA Yagi for 6m. Then I will utilize the full capacity of my 2x8. Amazing piece of kit 😁
73, Johan
Just as information if someone else would like to do this. My finished controlpanel and a snapshot of the config file.
- 325 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 936 Third-Party Software
