updating to v3.3.32 my experience
Just completed updating my 6600M to v3.3.32 Maintenance Release. (also updated SmartSDR on my pc as well)
After a couple of concerning bits of the power button flashing Red , ( two flashes then a pause then repeated) things finally looked like they were complete. BUT, it appeared the radio was stuck at 100% on the final stage of installation. After a bit, the screen went blank. But, the radio didn't come back up. I finally hit the power button, with some concern, and SmartSDR came up. The Waterfall looked kind of odd. The spectrum display was a full window width. But, the waterfall was only showing in the middle third of the screen. I touched the front panel and expanded the display to a much wider setting. And then brought it back to the width I had originally had v3.3.29. Everything was back to normal. So far, everything seems fine. I installed SmartSDR on my pc with no issues. I don't use the internal ATU so I cannot say that that issue is fixed. But, overall things weren't too bad.
3.3.32 install went fairly well for me using 6600 and win10. Followed instructions , the first install stuck at the end , waited 10 more minutes then held down the start button. when radio restarted ... clicked the SSDR icon and it wanted to upgrade again . This time it didn't take as long and finishes without a hitch . I powered the radio off did a cold boot , restarted , imported profile's and up and running . I never use the ATU ! If I experience any flaws , I'll update my post
Ed N5DG
My Update experience to 3.3.32 with 6600M
A month ago, I had install the 4GB SD card which i did purchase as i try to keep my gear current.
So update went smoothly by following the procedure...
i have not tested ATU as i use external tuner and everything else seems fine.
Being a MAC user, i tested XDAX and XCAT and WSJTX as well as Macssdr. No Issues found to date.
Hope everyone else has similar good experience
Paul K3SF
My Flex 6400 upgraded with no issues. I did purchase a spare SD card in the event things went South, but I did not have any issues what so ever.
Thank you Flex on making this a simple upgrade for the end user.
KN4YBA
I upgraded my early 6700 from 3.2.29 today. Due to it's old SD card, never changed to my knowledge at least, I was expecting it to crash during update. I was wrong. Update went smoothly, took appr. 10 minutes. To early to see any differences. Happy days, up and running again.
Johan, SE3X
I had two Maestro-related error messages pop up while trying to install 3.3.32 on my 6600M today. The load never completed. Very surprised and disappointed with problems like this on a maintenance release. I restarted and went back to 3.3.29. Mike W5QKM0
Hi Mike, I would suggest submitting a help desk ticket.
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 259 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 905 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 714 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
