3.3.32 error message then closes when accessing memories
When I attempt to access memories using SmartSDR 3.3.32 I get a LONG list of errors "SmartSDR (v3.3.32.8203 ) An unhandled error has ocurred. The Displayindex for the DataGridColum with header "group" is out of range " and many more . When I then try to proceed SmartSDR closes .
Windows 10
Flex 6400
Andy K3UK
Yes indeed, I thought this would be a major pain but I merely selected Import Memories from the Profile backup and that solved it.
Despite saving some profiles with the earlier version, I do not see any profiles when I attempt to import using the new version. What is the usual folder that profiles are stored in ?
Andy K3UK
Do a search on your PC for *.ssdr_cfg to find where your exported profiles are.
The memories themselves will be in your backup folder as
SSDR_Memories_xxxxxxxxxxxxxxx.csv
To make it easier next time, make a note of where you export the profiles. It will save you time and a bit of aggravation.
Just a thought...
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
