Is the PA in the 6400M common to HF bands & 6 meter band
TX band setting is 100w.
Any other settings to check ?
thank you
Hi Joe, what is your TX DAX level set to?
Hi Len....it is set to 50 which is the same setting used on HF bands that gives 100w
73 joe
Have you tried transmitting into a dummy load? If that gives the same results, then you should probably submit a help desk ticket.
You may need to adjust the Audio Transmit Level slider in WSJT-X. I have mine at around 80% for 100W out on 6 meters with my 6400M. Good luck and I hope you find the cause of the issue.
As a test:
Set your Tune on the Radio to 100%
Press Tune and while txing into a dummy load, read the power on your watt meter. If greater than 90 watts, all is ok with the radio and check your audio drive levels. If less, open a support ticket.
BTW, on audio drive, never exceed -5db on the level meter.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
