Is the PA in the 6400M common to HF bands & 6 meter band
TX band setting is 100w.
Any other settings to check ?
thank you
Hi Joe, what is your TX DAX level set to?
Hi Len....it is set to 50 which is the same setting used on HF bands that gives 100w
73 joe
Have you tried transmitting into a dummy load? If that gives the same results, then you should probably submit a help desk ticket.
You may need to adjust the Audio Transmit Level slider in WSJT-X. I have mine at around 80% for 100W out on 6 meters with my 6400M. Good luck and I hope you find the cause of the issue.
As a test:
Set your Tune on the Radio to 100%
Press Tune and while txing into a dummy load, read the power on your watt meter. If greater than 90 watts, all is ok with the radio and check your audio drive levels. If less, open a support ticket.
BTW, on audio drive, never exceed -5db on the level meter.
- 314 Community Topics
- 574 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 242 SmartSDR CAT
- 174 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 119 FLEX-8000 Signature Series
- 855 Maestro
- 50 FlexControl
- 804 Genius Products
- 279 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 695 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 920 Third-Party Software
