Yet Another Display Issue with My 6600M
It was 0230 hours here in Weston, VT and I came down to the shack this morning to prepare and set-up for Field Day operations. I started the radio and no display. The display was completely blank and black. Even the small external monitor I have connected to the 6600M was blank too.
I waited five minutes and shut the radio off. Then I waited another five minutes and started the radio again with the same results.
So, I pulled up the email I received from Ken when I had my previous display issue and review the instructions on how to reset the display. I figured what do I have to lose.
I pressed & held the LOCK A & F1 buttons for at least 5 seconds. Nothing at all happened.
So I shut the radio off and waited five minutes and turn the radio on. This time the display was working and the radio booted successfully.
I'm leaving the radio on the remainder of the weekend (weather permitting) so I can work Field Day. Then I'll cycle the radio and see if the issue returns.
What a way to start Field Day 2022!
Field Day is next weekend, June 25 - 26.
HA!
Yes, I just knew someone would say that ...
I know FD is next week ...
I have a new computer and was going to spend my early morning today getting fldigi set up for RTTY & PSK operations and NOT wait until the last minute like I usually do ...
When the 6600M display decided not to show up I just rolled my eye because I just got the radio back from FLEX and had the original display replaced ...
Just what I need before FD ... another radio issue ...
There have been zero display failures since reporting this issue to the Community ...
I must have scared the radio after reporting this issue ... My guess is the radio does not want to be sent back to Texas ...
Also, on another note, I upgraded to 3.3.32 yesterday ... without issue ...
Well I came down to the shack and booted the radio ... no display ... I tried three times with the same results ... I can still operate the radio as SSDR runs w/o issue ... I just can't see anything on the radio. Even the external display I have connected is blank ...
Normally I would try and perform a reset of the display ... but I can't see anything on the screen so I'm SOOL ...
So, I performed a Cold Boot & Factory Reset ...
The display is back ...
I'm glad I have the display working again ... however, what's up? Flex has already replaced the display ...
I've gone from having a display that looks like **** ... getting it replaced ... and now I have a display that sometimes works ...
Well this issue has not gone away ... Put in a ticket yesterday and I shipped the radio back to Austin ... Let's see what they find this time ...
- 633 The Flea Market
- 127 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 928 Genius Products
- 339 Tuner Genius XL
