Install MARS board in recently acquired 6400.
MSTalon2
Member ✭
I recently acquired another 6400 with the MARS board/mod still in a separate box. The instructions are vague for installation. I currently own another MARS-modded 6400 that is still under warranty. (In addition to a brand-new 6600 which is also MARS modded) I’m wondering how to proceed, should I open my current radio to visually compare the hardware? I don’t want to void my current radio’s warranty but I sincerely would like to install the mod into the used radio (2 yrs older than my current 6400). I AM MARS certified and active in AFMARS R4. Your suggestions are most welcome!
v/r 73 de Ben W5SOF
v/r 73 de Ben W5SOF
Hi Ben, here is the documentation, is this what you already found?
FLEX-6600M-Ext-TX-Kit-Install-Instructions.pdf (flexradio.com)
I have done a 6400 and a 6600, pretty easy. As noted the instructions are easy to follow.
Thanks Gary! That’s NOT what I had! I can usually bully my way through hardware mods (even a TS-2000 SMD mod) but the Flex is a different breed due to all the proprietary stuff involved. Pictures help, HiHi! 730
Len, sorry the affirmative response and thanks was for you! Misdirected by me to Gary. Thanks again.
730 -
No worries! Were you able to get it installed and working?
No sir! Not yet. The radio is terribly smoked up (from a smoking environment) so I pulled the covers off and started the assembly in the garage rather than my shack! I’ll get back on it after Field Day. I quit in 1990 but have a morbid aversion to cigarette smoke so a little ‘airing out’ is in order. I’ll keep the thread open until the project’s finished. Thanks for your help. 730
The MARS board requires a Software Key as well. Please open a support ticket.
And, opening a radio doesn't void the warranty. That is an old wives tale in so many ways. :)
Thanks, Mike! I’m familiar with the authorization process. Waiting for the Field Day dust to settle before I put a bow on this particular project.0
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 259 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 905 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 714 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
