QRZ Credentials for QRZ
AC8L
Member ✭
Hi, just got my 6700, setting up SmartSDR for Mac. I am QRZ subscriber and using API token for log integration from GridTracker/JTDX. Can not really use username/password since I have 2-factor auth enabled. However I only see the username/password option from SmartSDR settings window. Is API token integration for QRZ supported from SmartSDR?
Hi Sandar,
I also have 2FA and SSDR for Mac, the only info needed for QRZ is the API Key...
Oh I see now, you're looking at the "SSDR Preferences", there you enter your user / pass and then go to the LogBook App under SSDR tools and open the logbook then go to QSL inside the logbook App and you will find under QRZ.com / Preferences the field for the API Key...
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
