Add TGXL to the panels on the right side of SSDR
Let's hope, when and if this will be implemented, that there will be a way to turn PGXL and TGXL panels off. I don't want them to clutter my screen when I don't have them. This of course goes for both Maestro and SSDR.
As SmartSDR sits today, if you do not have a PGXL turned on, you will not see the PGXL pane. When the PGXL is turned on, the pane becomes visible and you can toggle it on/off just like the other panes. See sceenshot below:
It would be safe to assume the the TGXL pane would do the same when it gets added.
You may already know this but I should also add that the panes are not limited to be just on the right side. They can be moved to the left side by simply clicking and holding left mouse button in the area in the top bar (blue circle), and dragging to the whole window to the left side. Alternately the whole pane window can be moved to a separate window outside of SmartSDR or even to a different monitor. By clicking on the arrow (red circle), this shifts the whole pane window outside of SmartSDR then you can drag the window to a different monitor.
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 294 FLEX-8000 Signature Series
- 969 Maestro
- 942 Genius Products
- 346 Tuner Genius XL
