Error PSL13V_B-09.49
Hi all
My 6500 will shut down, sometimes after 5 minutes of being on, sometimes hours later, occasionnally while transmitting, most of the time while receiving, and the following error message appears :
ERROR PSL13V8B-09.49 CHECK FUSE
Obviously the fuse is not dead, otherwise the radio would not switch on, so what do I need to check ? Using SmartSDR version 2.7.6
Thanks + 73
Paul F6EXV
Hi Paul,
I had that same error a while ago and documented the symptoms and steps I took to fix it in my case.
Hi Al
Thanks for your info.
I will see if this solves my issue.
Paul F6EXV
Al, I don't know if your advice helped Paul or not, but you helped me. I have a 6500 that has been putting out less wattage than I expect, and the voltage monitor drops quite a bit when transmitting. I took off the cover, removed the fuse, and cleaned the contacts. Bingo! less voltage drop and more watts out.
Thanks Al,
Jeff KT5N
Jeff,
Good to hear, suspect the dirty contacts may be common. Glad to hear it fixed it for you.
Al / NN4ZZ
Hi Paul F6EXV,
Did you get the power issue resolved and what solved it for you?
73, Al / NN4ZZ
Hi all
Well, I had it solved by sending it to maintenance in Germany. It was OK untill a few weeks ago, same symptoms….
Smetimes immediately, sometimes after 5 minutes, sometimes after half an hour… and of course always when the DX is replying…. Shall I send it again in Germany ?
Paul F6EXV
Any idea ??
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
