N3FJP and CW Keying on Flex-6400M
Any N3FJP/Flex experts been down this road before?
Tim N9PUZ
I went ahead and bought the keying interface from N3FJP. It really sends quality Morse and it works with any radio. You can also build your own interface, I think the details are on their page.1
Set up a Win Keyer emulator port in Smart CAT. In ACLog, select the Winkeyer emulator option and use that port number. N3FJP has help files that describe how to do it. I have done it this way for several years.0
Ken --
Do you do this without actually having a physical Winkeyer? I looked on the N3FJP site and also contacted Scott. He pointed my to some information but indicated I needed an actual Winkeyer or other keying device.
If you have done this without a Winkeyer I would appreciate it if you could elaborate.
Tim N9PUZ
You can do it virtually with the flex go into cat setup a winkeyer port
and point N3FJP to that point and setup as winkeyer
also works in N1MM , FLDIGI and anything else with the WinKeyer option like HRD DM780
Thank you! I will work it out this evening.
Tim N9PUZ
Based on the suggestions given I did some further research and in deed you can do this without adding any additional keying hardware. It works like a charm.
To recap:- Create a new virtual serial port with the CAT control and set it to be configured as a Winkeyer. Remember the COM port.
- Configure whichever N3FJP logging program you're using to connect to a Winkeyer for CW Transmit and tell it to use the COM port from Step #1.
Tim N9PUZ0 -
Yes anything with a winkey app- I haven't come across anything with that option it hasn't worked with. No hardware needed
Based upon your results, I set mine up to work the same way. I am getting the same flawless CW set up this way that I got using the serial port interface. What I didn't understand at first is that there is literally a Winkeyer option when you're creating the new VSP, and I initially set up the port as a CAT port. Once I figured out that there was a Winkeyer option in the port protocol dropdown menu in SmartCAT, it worked perfectly. Flex really makes everything simple.
73, de N4QM1 -
Thanks for this thread, it was a big help.
Once this is set up how do you get a sidetone so I can hear the generated CW? I have sidetone enabled in the CW panel in SmartSDR but not getting any sound when N3fjp is sending.
Thanks, Peter - WB6POT
@Peter WB6POT did you figure out how to hear the side tone for the CW generated in ACLOG? I have the side tone enabled in SMARTSDR but don’t hear anything when I test from ACLOG. Note that I do hear the side tone when I use CWX directly from SMARTSDR.
To be more specific on my problem
i can hear side tone generated through the flex main front speaker if I have that enabled and send cw from AClog but I don’t hear sidetone on the PC like I do when I send cw thru cwx panel.
When I send CW through smart SDR I hear the side tone generated on both the PC and the flex front speaker… So I normally have the flex speaker disabled so I don’t hear both.
It’s really only affects me during contesting Because I normally just use CWX. The transmit on tab and enter options are very convenient from AC log.
Hi Chris, the latency through a PC makes it impractical to bring a CW sidetone back to the operator that way. CWX works because it is sending CW generated from text, not paddles.
Even though ACLog is doing the same thing, it is doing it as if it were coming from paddles (using a WinKeyer CAT port), so SmartSDR doesn't send the sidetone to the PC.
I don't know if Flex or Scott, N3FJP have plans to change this behavior, but at least for now, this is how it works.
My ACLog is on a different computer. Is there a way to access the Windkeyer in the 6400M from my remote ACLog?
Yes,
Run SmartSDR CAT on your remote computer and do a Smartlink connection to the radio.
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
