Diagonal lines in panadapter
Dan KG0AQ
Has anyone come home to this? I was on vacation and used iOS a few times successfully.
Booted up at home and found this. Restarted, rebooted, unplugged, tried loading profiles and still the same. 6400 running 2.5.1 TIA!
Dan KG0AQ 73
Did you reboot Windows three times?0
Looks like a wide TNF (tracking notch filter). Click on the white TNF in the lower left and see if it changes color to confirm it is the TNF or right click and see what options are presented and delete it if you want.
No...Is that like a magic wand? hi hi0
It's an old support call type of video on Youtube (Language alert).
But David might have it right, could be a really wide TNF.0 -
I does look the TNF, but that looks pretty WIDE ? Not sure with 251 but with ver3 I think 6Kc is the widest ? Hopefully a reset will cure it !
Good luck !
Vidas1 -
David you are the winner with the TNF!! I have no idea how it happened but might be correlated to the use of iOS remotely? OR I did use teamviewer once because of a storm in the area. Thank you!0
Whew, glad it was an easy fix.
it's now May 19, 2022, 3 years later and this thread came in handy.
I have no idea how this happened... I just brought up Ssdr this morning and the spectrum was all yellow with diag. lines... I right clicked on it and deleted the TNF...Poof, fixed.
Something is glitchy.
Would be interesting to “zoom out” to view a wider selection of the pan and see how wide this is.
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 209 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
