SD CARD in Store -- Does it support V2.X ?
In the store the SD Card is titled FLEX-6000 Series Version 3.X SD Card
Does it also support V 2.x (and specifically V2.4.10)?
I am still on V2.4.10 and have not paid to upgrade to V3.x because I don't want the AutoProfile save feature. I also don't need any of the other features in V3.X but would upgrade if the AutoProfile ON/OFF option was implemented.
Thanks...Al
No, Version 3 only at this time.
Mike wrote: “No, Version 3 only at this time”
Does that imply that there will be cards sold eventually that support the versions of V2 that are still otherwise supported?
V2.4.10 and V2.7.6
Thanks, Al / NN4ZZ
Mike,
If there won’t eventually be a SD card in the store for V2.4.10 and V2.7.6, is it correct that I can still wait till I get the error and send in the 6700 to get a new card that supports V2.4.10 at no charge?
Via a help desk ticket…
Thanks, Al / NN4ZZ
Regarding wanting V2, and receiving a V3 card......It seems that you could, first, load the V3 firmware, then downgrade to V2.
Alan. WA9WUD
If anyone is reading this, before you consider jumping through hoops to go up to 3 and back down to 2, we have not tested it at this time. You might not like the result due to the many changes in the file structure.
Please keep that in mind.
Mike,
Agree, would prefer to get a card that supports V2.x directly and not have to do the downgrade and deal with the other structural changes.
So would like to know if that is going to be coming at some point…
Thanks, Al / NN4ZZ
Al NN4ZZ's point of view echos my own.
Tim K9WX
Submitted a help desk request to get more info on the options for those that are running V2.x to get a SD card.
Al
No need to submit a ticket. Getting version 3 out the door was the priority. Part of the reason being is that most of our customers are running Version 3. Some are still on Version 2.
As to the future of Version 2 and whether we will we do the same thing, that has yet to be decided. When we have the answer, I will share it here.
The policy is that we will not announce anything until we know we are able to deliver the solution.
Here is what I’ve learned so far.
Flex may or may not offer a SD card for V2.x in the store. This is just following their policy of not making any announcements about product offerings before they are announced. So fingers crossed…..
If your radio bricks, and you send it in for repair they will return it with a SD card that matches the latest version of software you are licensed for. So for V2 users that is V2.7.6. It looks like for those of us on V2.4.10 we would have to reload/downgrade to V2.4.10. I’m waiting for a final answer on that.
Bottom line for V2.x users is wait and see if they offer a V2 card or wait till our radio fails and send it in.
73, Al / NN4ZZ
Thanks Tim E for the Help Desk replies,
The help desk confirmed this: In the event of a SD card failure of a radio using V2.4.10, the user would submit a help desk request. Once the issue is confirmed the user would be sent a card for the latest V2 version, V2.7.6 and need to downgrade. No special process needed to do the downgrade, just reload V2.4.10. Also, No charge for the replacement card and they include an envelope to return your defective card.
The pro of waiting for a failure and dealing with it then is “no charge”
The con is the longer downtime.
If they eventually offer a V2 card in the store, I’d be fine with paying for it to have the quicker fix. Mike said he would update us here when a decision has been made.
73, Al / NN4ZZ
Can we get the sd card in the uk, the last time i tried to order a Flex hat, i was told contact your local dealer,he doesn't keep them in stock, still doesn't 2 years later.
Paul, you should be able to order a card and have it shipped to the UK. Can you test it and if it doesn't work, drop me an email at info@flexradio.com. Be aware, the shipping will not be trivial.
Sometimes the localization does strange things.
Mike,
It has been nearly four weeks since SmartSDR v3.3.29 was released with fixes to prevent premature SD card failure. In the meantime radios running v2.x will remain indefinitely vulnerable to SD card failure without a maintenance release.
What is the status of the SmartSDR v2.x and availability of v2 SD cards through the Flex store? Isn't it time that Flex provide its customers running SmartSDR 2.x with some forward visibility on this problem? If Flex is going to discontinue maintenance support for v2.x, I hope the price of an upgrade to v3 would include a new replacement SD card for older radios with vulnerable 256MB SD cards.
Larry KB1VFU
Thanks Larry
I will pass on your comments to our engineering group and share your concerns.
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 181 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
