TGXL Remote
My questions are:
1-Should I leave it on all time so it will be ready for my use remotely?
2-Well the TGXL will remember the stored tunes so it will save my PGXL?
73's
Hamad
A71VV
Best Answers
Hi Hamad,
Most of us that run remote use AC power outlets that can turn the DC power supply on and off remotely. I use the DLI Web Switch Pro. https://www.digital-loggers.com/lpc.html
They also make an AC relay which can be connected from one outlet to the Remote On connector on the Flex which allows you to turn the radio on and off. https://www.digital-loggers.com/ac.html
The Tuner Genius XL will remember the tuning memories when powered off. If the SWR is too high, the Power Genius will stop transmitting very quickly to protect the amp.
Some of us use Node Red to control and monitor the radio, amp, tuner and 2x8 Antenna Genius. This allows control from any web browser, including Safari and smartphones.
Open a support ticket with Flex. Some users have experienced the fan running full speed when applying DC power. From what I read on this Community, this seems to be due to the DC voltage on the power supply coming up to full voltage slowly.
If you have an extra AC Relay, try supplying the DC positive to the tuner through the common and normally open contacts on the relay. Leave the outlet for the tuner AC Relay off. Turn on the DC supply outlet first, then turn on the outlet for tuner. That should allow the DC supply voltage to stabilize first.
Again though, I recommend opening a support case. It is possible the support team has more information or updated information.
73 & good DX
> @"David Decoons, wo2x" said:
> Hi Hamad,
> 73
> Dave wo2x
Hi Dave,
Thanks a lot for your time and your answer, I actually use both AC power outlets and the AC relay for flex radio so we can control it remotly.
My main issue is the TGXL power switch as it looks that I should keep it on all time and powered on. in fact I switched my power supply remotely Off and that's ok but when I switched it On back, the TGXL didn't start and I have heard high speed fan is running.
I hope that Flex radio team with 4O3A teams can come with permanent solution to control the TGXL via flex application and to come up with AC relay similar to the one we are using for the radios.
73's
Hamad
A71VV0 -
> 73 & good DX
> Dave wo2x
Thanks Dave :) I just install RD Client on my iPhone and I am able now to control my TGXL very easy, remaining is switching the TGXL DC power on/off via the relay :(0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
