Connecting Digital with Maestro
Best Answers
Sorry for the delay in replying. Yes! :) Cool, eh?
This is a normal setup and NOT a MultiFlex setup since there is only 1 operator.
MultiFlex is when you have 2 versions of SmartSDR running as in 2 operating positions.
Hi Glenn, When you run SmartSDR on the computer to set up CAT and DAX, it needs to match the version that the radio is running. The Maestro version also needs to match the radio version. Version 1.12.1 is the most recent V1 software. If your radio and Maestro are less than this and you don't have that version of SmartSDR, you will need to bring both up to 1.12.1 so that SmartSDR will match.
If you are running a digital mode on the computer with the Maestro providing operator control, you will not be running SmartSDR, just CAT and DAX. In this scenario, MultiFlex is not being used because the computer is not running SmartSDR, just the digital program plus CAT and DAX.
If you want everything on the computer, leave the Maestro off and run SmartSDR (along with CAT and DAX) and your digital program.
Hi Glenn, the digital modes will need a computer to run on. They can coexist with the Maestro or with SmartSDR on the same or different computer.
The audio for your digital programs will not use the Maestro. The operator will use the Maestro.
On the computer with WinLink you want to install SmartSDR which will install SmartSDR CAT and DAX. WinLink will use the CAT and DAX programs to connect to the radio directly. This makes it a much cleaner and more efficient solution.
This video might help https://youtu.be/reXN3rpIaZU
Mike-VA3MW. Does this mean I leave the Maestro connected and then connect the computer via the network and I don't have to take the Maestro offline?0
If the software version is 3.xx, both the computer and Maestro can be connected simultaneously, called multi flex. Both can be operating the radio simultaneously, even by two separate operators, which can be remote if desired. Or some use the Maestro in smart control mode to use the knobs.
The Maestro uses an OEM tablet with a minimal version of windows to get touch screen capabilities for SmartSDR, but it can’t run any other programs.
Mike, does it matter what version of SDR I run if the Flex is still less than Ver 2.00
Thank you Len.0
- 109 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
