flex 5000a Hole (UHF) VU5K
I noticed that in some models of flex 5000a in the rear area there is a hole with UHF label, I assume it is to position the BNC for the UHF band. i am about to buy the VU5K module but i noticed that in my superb flex 5000A there is no hole. do i have to drill the hole for the BNC myself?
  • Alan WA4SCA
    Alan WA4SCA Member ✭✭
    edited April 2022
    This is the back of the 5K with factory installed V/U board. So, unless the board also comes with the back panel, some drilling will be required unless there is another way to route the connections.
  • IK8HCG
    IK8HCG Member ✭✭
    edited April 2022
    this is mine Flex5000A
  • W1IMD
    W1IMD Member ✭✭
    I am quite certain that you will not be able to purchase the V/U module from Flex. At the time they were offered, the radio had to be returned to Flex for integration. It was never an option for self install.
    Paul
  • IK8HCG
    IK8HCG Member ✭✭
    are you sure what you say? the upgrade has already been performed by local friends. the only thing i noticed is the lack of the hole in my flex.
    I buy the module privately
  • W1IMD
    W1IMD Member ✭✭
    I am quite certain of what I have said. What you do privately is up to you. Why not swap back panels with the person you're buying the module from?
