TX slice not toggling according to N1MM SO2R slice command suddenly
Kari Gustafsson SM0HRP
Hi contesters, anyone experienced this problem. Loading previous global and TX profiles that allowed toggling of TX slice as N1MM changes then in SO2R will not accomplish this TX slice toggling anymore. I can switch active slices in N1MM but TX slice remains. Only way is to do this manually.
The OTRSP config is correct. Is there any other way to troubleshoot this unlucky behaviour?
Latest versions of Smart SDR and N1MM is being used.
Soon CQ WW....:(
Soon CQ WW....:(
Will it fix itself if you use a few CTRL+left and CTRL+right sequences? Andy KU7T0
Hi Andy, I doubt. I used the Pause key to switch between slices since it is easier and always have worked. Have you tried to switch slices after the new versions of both software? Do you know how to troubleshot the OTRSP commands and if they are issued?0
Did you try it? Andy KU7T0
No, I will. 73 Kari0
HI Andy,
Just tested and CTRL+left arrow or right does not work either.
When I look in the profile manager (global profile is a SO2R profile) and switch TX slice by pressing manually on the TX1 button or TX2 button I do se that SO2R_TX1 is loaded and SO2R_TX2 is loaded respectively for the TX profile. The way it should.
So is it N1MM and/or OTRSP that is not working correcty?0 -
You ever figure out this? I'm having the same issue.
I am wondering if anybody can help. TX profile is not following the active slice.
Clicking on N1MM radio 1 entry window it changes the active slice on the radio but Tx profile does not change. If I use slice master at the same time when clicking on the corresponding cw skimmer waterfall the TX profile follows accordingly the active slice on the radio and the correct entry window of N1MM.
Appreciate any input.
Thank you, Alex AK1MD
Edit (deleted the first entry).
I just tested this and it works fine, but I had to review the manual on TX Profiles - Section 18.2.
TX Profiles are linked to the TX Antenna setting in the transmit slice.
If you keep this in mind, is that how it is working?
Mike va3mw
- 650 The Flea Market
- 152 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
