Eero mesh and SmartLink issues
The title mentions smartlink. Is this a remote over-the-internet operation or is it a local over-the-lan operation? If the latter, smartlink is not appropriate. Smartlink is only for over-the-internet operation.
Thank you, John. The local SmartSDR using IOS works without issue. What I am trying to set up for mobile use on my iPad is Smartlink. I keep receiving:
Manual TCP port: Failed
Manual UDP port: Failed
Automatic TCP port: Failed
Automatic UDP port: Failed
Hole Punch: Failed
I do not have direct ethernet access to my ATT DSL router and must use ethernet on an Eero mesh hub.
Tom KD9TB 73
Hi Tom,
I have the Eero Pro 2 mesh system currently and SmartLink works.
Please check the following.
What is the WAN IP address of your DSL modem?
Go to whatsmyip.com and see if that IP matches your WAN IP. Yout ISP may be doing carrier grade NAT. That means they use one public IP address for many customers. That would require your ISP to do port forwarding on their end to your WAN IP.
Let me know results of the items I asked you to check. Feel free to e-mail me direct. My e-mail is good on QRZ.com
Tom,
One comment, if the -1 is showing in your "Network Settings" for the external port numbers, you either need to set the TCP and UDP external port numbers for EXTERNAL ports you have set in your router. I always liked to use a different external port numbers than what the internals are, but some just leave them the same, here is what mine looks like . Or you can turn on UPnP ..
Dudley, WA5QPZ
Thank you. Your response was very helpful. I tried the TCP and UDP external port numbers you suggested. No joy. However, my ISP (AT&T DSL) likely has a NAT issue. I will follow up with them today. Thanks again. Tom KD9TB 73
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
