FLEX 6400 and N1MM Split problem
Cees
Dear members,
According to the FLEX6400 manual (Split) everything is correct when I work with the key.
Unfortunately that doesn't work when you work with the N1MM log program. The FLEX6400 no longer works in split from the pre-programmed memories.
Does any of the members know how I can solve this problem?
Yours sincerely
Cees, PA3CVI
Solution is very simple.
FLEX:
open a single slice for transmitting and receiving on the same frequency.
N1MM:
Click on the entry N1MM window and press the <CTR> <ALT> S buttons, then the word "Split" will appear in the window.
FLEX:
In FLEX, a 2nd slice is now open, on which a split is sent.
N1MM:
Again in N1MM the command <CTR> <ALT> S excludes the Split mode again
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
