FLEX 6400 and N1MM Split problem
Cees
Cees Member ✭✭
edited March 2022 in Third-Party Software
Dear members,
According to the FLEX6400 manual (Split) everything is correct when I work with the key.
Unfortunately that doesn't work when you work with the N1MM log program. The FLEX6400 no longer works in split from the pre-programmed memories.
Does any of the members know how I can solve this problem?
Yours sincerely
Cees, PA3CVI
  • Cees
    Cees Member ✭✭
    Solution is very simple.
    FLEX:
    open a single slice for transmitting and receiving on the same frequency.
    N1MM:
    Click on the entry N1MM window and press the <CTR> <ALT> S buttons, then the word "Split" will appear in the window.
    FLEX:
    In FLEX, a 2nd slice is now open, on which a split is sent.
    N1MM:
    Again in N1MM the command <CTR> <ALT> S excludes the Split mode again
