Setup instructions for WSJT-X with MAC SmartLink SDR
I am a brand new 6600M owner using an Apple M1 iMAC. Rather than using the FT-8 that comes with Mac SDR, I would like to install the WSJT app and link it to the SDR. I am new to DAX and CAT controls for MAC. I need help. Thanks. Tom KD9QHX
  • tomblasco
    tomblasco Member ✭✭
    Answer ✓
    Thanks, I have downloaded xDax and xCat and am attempting setup now!
    Tom KD9QHX
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    edited March 2022
    You will need a tool such as Loopback, which provides an audio device from application to application. The audio connector is treated as an audio device by SSDR for Mac and by the WSJT-X or other digital app. There are also a few other apps which will do the job - and they are generally not free. The free ones in the past were not very good. Contact Marcus (author of SSDR Mac) for information on getting a break on the cost of Loopback from Rogue Amoeba software.
    There are quite a few articles in the Community with help for doing this.
    By the way, you can use the Loopback driver to connect both to SSDR and to the “M” front panel GUI in the radio, at the same time.
  • tomblasco
    tomblasco Member ✭✭
    Thank you! Tom KD9QHX
  • Alan
    Alan Member ✭✭✭✭
  • Ted  VE3TRQ
    I should have mentioned that connecting from a Mac to the “M” front panel requires xDax and xCat :-(
  • K3SF
    K3SF Member ✭✭✭
    edited March 2022
    i run macbook air M1 easily with my 6600m using front panel
    first need to down load XDAX and XCAT
    second need to load Loopback for audio routine within the mac
    third need to build audio routinng devices in loopback
    fourth select those devices in XDAX
    i here are some pic of how to config loopback device
    and
    xdax setup
    you will notice i have wsjtx specific devices inloopback
    caus ei also run fldigi for rttty
    and built similar set for fldigi
    having separately defined devices keep my accidentally using the wrong app
    with just the front panel you can easily run two slices on different bands for FT8
    i have run macssdr with 4 slices and separate loopback devices for that configuration
    at the end here, i show one example of how to build loopback device when using macssdr
    Hope this helps
    Paul K3SF
    Screen Shot 2022-03-16 at 7.59.28 PM.png Screen Shot 2022-03-16 at 7.59.11 PM.png Screen Shot 2022-03-16 at 7.58.56 PM.png Screen Shot 2022-03-16 at 7.58.29 PM.png Screen Shot 2022-03-16 at 7.58.13 PM.png Screen Shot 2022-03-16 at 7.57.59 PM.png Screen Shot 2022-03-16 at 7.57.48 PM.png Screen Shot 2022-03-16 at 7.57.32 PM.png
  • K3SF
    K3SF Member ✭✭✭
    when running multiple FT8 i would recommend using JTBridge as this will connect to all instances of FT8
    https://jt-bridge.eller.nu/
    and
    gives you a integrate view of stations onthe air
    JTBridge interface swith macdxlogger for logging those contacts too.
    paul K3SF
  • K3SF
    K3SF Member ✭✭✭
    scrypt to run multiple instances of FT8
    note the path to wsjtx app on my macbook air is
    /applications/HamRadio/WSJT/wsjtx.app/
    all you need to do to make these scrypt work fro you is to substitute your path to the wsjts.app
    PaulK3SF
  • tomblasco
    tomblasco Member ✭✭
    Thank you! I'll work on implementing your recommendations today. Tom KD9QHX
