2 Active Panadapters /Slices on 6400 With SmartSDR for MAC
I have yet to be able to show two slices with matching pan adapters, ie one slice with pan adapter on 15 meters another slice with pan adapter on 20 meters. I am using the latest version of SMartSDR for the Mac , MAC M1 Mini with a 6400. Any suggestions?
Jim
Best Answers
Create a second (new) panadapter:
Then, create a new slice, in the new Panadapter:
Alan. WA9WUD
Thank you. I was creating the second slice then the pan adapter. I now know the correct sequence.
Again Thanks
Works no issue at all - I have a 6600M, and have 4 panadapters and slices open - the Mac has 2 open no problem, along with 2 on the M front panel.
Ted can you walk me through the steps you did to get the multiple slices please?
Sure, Jim - be a bit later today, but I have a profile set up that just does it for me, and persistence will usually look after it form one instance to another.
Jim, you realize that a 6400, unlike the 6600, supports a maximum of two slices?
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
