DX Engineering NCC-2 Remote Module
I had purchased a Flex 6600 new to me with the intention of keeping my home office free of radio equipment (I have multiple computers for work) so I had decided to go down the path of SmartSDR on one of my monitors with a large closet for a radio rack. Unfortunately the NCC-2 defeats that intention.
A second benefit of enabling remote control with stepper motors of the Antenna Phase Controller would be enablement of memories for bands to local interference (QTH is urban Nashville) and it is not quiet (both my houses noise and also a multitude of local AM high power stations).
Thoughts? I wish the Beam Forming via software was implemented, but as that has been in the backlog for multiple years I think this might be the next closest option.
Tim
I, too, have a DX Engineering NCC-2, and my Flex is remote from my shack.
Your proposed solution seems complicated, for the benefit gained.
In my case, I am using noise cancellation software on my PC, to reduce noise. There are many "plug-ins" available, for this purpose, to be used with a Digital Audio Workstation, DAW, of your choice.
One such example is the RX9 Noise tools, from Izotope. https://www.izotope.com/en/products/rx.html
Alan. WA9WUD
Hmm, the RX9 Noise tools look interesting, but that is audio only after the signal has entered the Flex whereas the NCC is reducing local interference (mostly from your household electronics RFI) and increasing the SNR directly from the antenna. I agree it might be a little complicated, but we shall see.
Tim
I agree with your comments.....always better to eliminate noise at the source.
But, in the case of the NCC, you are not gaining signal to noise ratio.....the ACC inputs two receive signals, one of which, presumably, is the noise (but in the real world, it also contains some portion of the desired signal), and thru an adjustable phase shift, cancels one from the other. There is no S/N enhancement, because both receivers, contain "signal".
Take a look at the RX9, https://www.izotope.com/en/products/rx/for-post.html
It continuously samples the audio stream, and then uses an AI algorithm, to only pass the voice audio. I found, using this plug-in, the Flex AGC is much less needed.
Alan. WA9WUD
- 112 SmartSDR+
- 944 Maestro
