Change Default Location of Radio Control Panel
The radio control panel appears to default to the right side of the SmartSDR display. Although the radio control panel can be popped out and moved around, is there a setting in SmartSDR to have it display on the left side of the display when it's not popped out? In some of my use cases, it's helpful to have the radio control panel on the left side of the screen; popping it out works fine, but I've not located a way to flip it to the left side when not popped out either in the SmartSDR User Guide or in the forums.
Mark
AC3EW
Mark I thought this could be done...I clicked on the box where the tabs are located...TX, P/CW, PHNE etc. and moved it over to the left side. It took a couple of tries but it did work. Give it a try.
Ronald
Ronald, that worked! It helped me to take SmartSDR out of maximize to allow more room for placement of the panel, and it's there now. I closed SmartSDR and brought it back up just to ensure the window configuration stayed put, and it does.
Thanks!
Mark
AC3EW
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
