Maestro-Its been reported that Maestro needs to run or charge every 30 days
Mentioned in some reviews of the Maestro, people report that if you dont run or charge your Maestro every 30 days, the internal battery goes flat, and you must send the Maestro back to flex for repair.
Could this be true?
Craig
W1ZN
Craig I would not stay away from the Version A. I had very good service from mine. Most of the time...when people had issues...and I say most...the Maestro was placed on a self...the user would take it down after several months expecting it to work and the internal battery had died...the key is just use it time to time.
Ronald
Craig I have owned Version A and Version B Maestro. Version A really needs to be used once a month to keep the internal battery charged. This issue was addressed and corrected in the Version B model. I would not recommend letting the Maestro sit for an extended time without being plugged in....just my 2 cents...BTW I was very pleased with both versions....
Version A the power button is on top and Version B the power button is on the left side. Hope this helps.
Ronald
Wrong. Only on the original Maestro Rev. A is a dead internal Dell Tablet battery possible. It happened to me when I was inactive for 8 months and had it disconnected. There is a procedure to charge it. Not very difficult at all. See this forum discussion:
Bill, NE1B
Thank you Bill,
Craig W1ZN
Thank you Ronald. I think I will stay away from Model A.
Craig
W1ZN
I have had my Model A version for a very long time and it is a VERY small task to take it from my case and plug in the +12V supply and charge once a month, I have also heard of the Version B Batteries swelling and messing up the display so take it for what it's worth they both have one problem or another.
I also modified my Maestro A and brought out the charge cable out to the external battery case so if I need to charge the tablet battery when it get's to low it is easily done by plugging a 5 Volt charger directly into the tablet so no problem even if it doesn't get charged every 30 days I just thew the old 2 Amp microUSB charger on it over night and swap cables back and away I go. Oh I can also plug it into my external battery pack 2A USB charge port with my Modification and have it charge the internal battery if I am out in the field and run into issues.
Thank you for all those details.
Craig
W1ZN
I still use my Maestro A every day and I got it the first week it was shipped about 2014.
If you can find an A, buy it and use it.
Hi Mike,
Thank you for sharing that great experience.
73, Craig
W1ZN
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
