6m & 60m output
Dougrea
Why does 6600M limit my RF power to 55w? I have both bands set to 100w in the transmit settings
A pleasure to help.
Check the “Max Power” setting in the “Transmit” tab of the main menu.
I have all bands set at 100 W and I get full power on all bands except the 2 bands mentioned.0
How about the front panel power control (the outer ring of the control to the right of the “ATU” button) ?
It doesn’t let me turn past 55. The transmitter is set at 100 and works on all bands except 6 m and 60 m.0
Actually Neil you were right the very first time. I went back and reread what you wrote. I was checking the transmit band settings. But I did not check the transmit tab. I moved it to 100 W and the problem is solved. Thank you so much0
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
