6m & 60m output
Dougrea
Why does 6600M limit my RF power to 55w? I have both bands set to 100w in the transmit settings
A pleasure to help.
Check the “Max Power” setting in the “Transmit” tab of the main menu.
I have all bands set at 100 W and I get full power on all bands except the 2 bands mentioned.0
How about the front panel power control (the outer ring of the control to the right of the “ATU” button) ?
It doesn’t let me turn past 55. The transmitter is set at 100 and works on all bands except 6 m and 60 m.0
Actually Neil you were right the very first time. I went back and reread what you wrote. I was checking the transmit band settings. But I did not check the transmit tab. I moved it to 100 W and the problem is solved. Thank you so much0
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 34 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 903 Genius Products
- 326 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 983 Third-Party Software
