Problem retrieving current CWX macros
Using Flexlib, my program can set a new value for a CWX macro by using the radio.GetCWX.SetMacro function and the new macro is displayed by the CWX Setup panel and it works when the corresponding PF key is pressed.
There seem to be two ways to retrieve the current value for a macro. One is to reference the string returned by the radio.GetCWX.GetMacro function specifying the proper index and a return string. The second is to reference the proper element of the array returned by the radio.GetCWX.Macros property. Both ways return the same result.
But I'm having a problem. After I load a global profile (which loads CWX macros) and then subsequently modify one or more macros using radio.GetCWX.SetMacro, I find that a subsequent query (using either method) still returns the obsolete macro that was loaded by the global profile -- even though the macro has really been updated. (The latest macro really is there and is sent by the radio when the corresponding PF key is pressed).
What am I missing to be able to retrieve the current macro(s)?
Second question: what is the radio.SyncCWX property used for? In my case, I find that the current value is True. Is it somehow involved with what I am missing?
Regards,
Howard, K7JNX
  • Eric-KE5DTO
    Good questions. First, what version of SmartSDR are you using? It looks to me like we rely on the status messages coming back from the radio to update the strings in FlexLib. I'm not sure why that wouldn't be happening as expected, but I'm looking into it.
    The SyncCWX property is used to ensure that the various CW related settings (WPM, delay, etc) are kept in sync between the regular paddle settings (CW) and the generated CW system (CWX).
  • Eric-KE5DTO
    Looking at this some more, I see the problem you describe on our latest internal code and it looks like a bug to me. I entered this as SMART-8718 CWX: Macro Save doesn't have expected status messages. Thanks for helping identify this!
  • Howard  K7JNX
    Howard K7JNX Member ✭✭
    Thanks for responding, Eric. It is SSDR v3.2.39 - I should have mentioned that.
    Is there any hope this might be fixed soon? I'm writing an interface to Touch Portal to handle CWX activities.
  • Howard  K7JNX
    Two years later, what's the status of SMART-8718?
