Can someone tell me what type of switch is the Power Switch on the Flex 5000a
adr
adr Member
edited February 2022 in FLEX Series (Legacy) Radios
    Here is a link to the Flex 5000 service manual. I believe it has a list of parts. Hopefully this will help.
    https://www.flexradio.com/documentation/flex-5000-service-manual/
  • adr
    adr Member
    [{"insert":"thank you for responding I have a service manual and a parts list but it doesn't tell you what type of switch\nLike a on-off or a momentry switch. I need to replace it. no one near me wants to have anything to do with it.\nThank you again for the info I wont be buying ant more Flex equipment they take your money and only supply\nonly half of what you pay fore and don't reply to any Emails.\nKind Regards\nDoug vk3awo. \n"}]
  • bahillen
    bahillen Member ✭✭✭
    Try a help desk ticket
  • adr
    adr Member
    [{"insert":"Thanks for comment,that was a complete waste of time.they said it was too old and proberley wouldn't have the parts.\n\n\nKind Regards\nDoug Vk3awo\n"}]
    It looks like DigiKey has it.
    K5V1BU43T C&K | Switches | DigiKey
  • bahillen
    bahillen Member ✭✭✭
    With old equipment sometimes a fellow ham has a parts only radio on the shelf with a part you are looking for.
    I have also removed a bad switch and was able to repair it if you are handy.
    As a last resort you could hardwire the switch and use an external switch.
    Does any of the others on this blog have a parts radio that can help?
    if you have removed the switch can you post a picture? May help
    Bill W9JJB
  • N0DFF  Steve
    N0DFF Steve Member ✭✭
    Troy Radio Service supports the legacy Flex products.
