INTERFACE mldx and macssdr
I am using a 2021 macbook air M1 (mba) with monterey 1tb ssd and 16gb ram..nice little machine
it easily runs macssdr
radio is flex 6600m.
what i need to accomplish is to have mldx see macssdr
so i am using multiflex with macssdr so the 6600m is split between
main screen on 6600m and macssdr.
mldx always defaults to the main and no way i am i able to make mldx select macssdr
even when running mldx on same machine as macssdr
as side
...i am able to run four slices in mba
and
with xdax/xcat i can run four instance of wsjtx-FT8 and jtbridge
and
all ft8 contacts get properly logged to mldx
thanks
Paul K3SF
well aftersome experimentation, i finally figured out how to force mldx to see macssdr on my mbair M1
step one...force macssdr to use all slices (aka 6600m resources ) and disocnnect the front panel a ssdr gui. this makes mldx only see macssdr as valid gui for the 6600m (see mba8 pic)
now able to selectmabook air gui of macssdr
before that macbookair was not an option to be selected inside mldx at all
there was a hint in mldx manual that mldx looks for a valid ssdr gui to connect to
so once i forced only and only one gui to be macssdr, then mldx added it to its list
hope this help other who want mldx connected to macssdr for logging and for using mldx cluster/spots panels
Paul K3SF
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
