Flex 6700 on 2m- a high gain PA instaed of a transverter
This radio provides a low level signal on 2m band and rather than a transverter a high gain 2m power amplifier could provide a reasonable power output on 2m band. I recall a company with website fmbroadcastparts.com which used to manufacture such amplifiers but unfortunately their website is inactive. Alternatively, a pre-driver to a typical 2m "brick" type PA could provide sufficient power to drive it ( usually 3-5W) .
Any comments/suggestions about this idea?
Tom
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    Q5 Signal sells a low-drive, two-meter amp that works well with the Flex 6700.
  • Mr Radio
    Mr Radio Member ✭✭✭
    OK, Thanks for info, OM Neil.
    I will contact Q5 Signal.
    Tom
  • David Decoons, wo2x
    I bought the 2 meter LDPA from Q5 Very satisfied.
    One thing I recommend is to run the 6700 on an external reference oscillator such as the ones on eBay for about $100. Without the external oscillator there is a longstanding bug that the RX and TX frequency are off from each other.
