How to? RTTY Skimmer (VE3NEA) und Flex 6400
Hi,
i want to test RTTY Skimmer Server next weekend in the WPX RTTY Contest but have problems to get it running. Use SSDR 2.62, newest V 3 SDR-Bridge and RTTY Skimmer Server Soft. Tried to install with the "how to guide" "EZ Start Setup RTTY, by N5AC" and also editted the .INI files from the RTTY Skimmer Soft.
I think the decoder from Skimmer Server dont get the IQ-Stream from the Flex. I read many about problems to get it running but no real solution!
Any help from the community?
best 73s Bernd, DL9YAJ
  • LB5GI
    LB5GI Member
    Same problem here
    73 de LB5GI Gjermund
  • DL4RCE
    DL4RCE Member ✭✭✭
    Hi all, disable IQ stream in DAX Software, it has to be grayed out, otherwise will not work.
    73, Volker
