How to configure two instances of N1MM w/WJST-X on the same computer?
I have a Flex 6600M and would like to run two instances of N1MM w/WJST-X at the same time, one instance for Slice A and B and the other for instance for Slices C & D? I believe I would have to at least download and install N1MM into a 2nd directory, separate from the default directories N1MM creates. If this is possible, what would the configuration look like on the Flex? Duplicate the virtual COM ports the instance one needs? Has one got this to work? Thanks
While you can configure and use two instances of WSJT-X on the same PC, N1MM will not allow more than one instance on the same computer ( With or without WSJT-X ). I am not sure if one instance of N1MM can run two instances of WSJT.
To run two instances of WSJT-X you would use the WSJT-X's -rig_name command line option ( as document in the WSJT documents ) . And you would need to configure SSDR CAT for a unique port for each instance and use separate DAX channels for RX.
AL, K0VM
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
