Rx A and rx B
John GM7PBB
Hi John, do you have the RF Gain, Audio Gain and AGC-T set the same in B as you have in A?
Hi Ken. Yes I made sure both were set the same, if I turn the rf gain up to +40 on the RX B I get a low signal but nothing like RX A is. its as if RX B is deaf, even the transverter port woks perfect.
Thanks.0 -
I meant Len :-)0
Hi John, No worries, I get Ken, Glen, Ben... 😀
It sounds like a problem with the radio. I would submit a helpdesk ticket.
What was the outcome of this issue ??
It would be good to know and great knowledge for the Forum and others to see.
Karl.
John - I'm not sure if this has a bearing on your question, but if you have your internal ATU engaged this might answer your question. Take a look at the Flex 6700 block diagram on page 40 of the Flex-6000 Hardware Reference Manual This diagram shows the common switch connection on the RX A Out switch routing back make a connection before the ATU, in other words the RXA connection runs through the ATU. Now follow the connection from the RX B Out common switch and you'll notice it does not go through the ATU, but rather goes directly to the ANT2 Relay.
If your internal ATU is engaged perhaps this is why you are noticing lower signal on RX B. (Of course if your internal ATU in in the bypass mode, there shouldn't be a difference.)
Butch, KF4HR
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 258 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 148 FLEX-8000 Signature Series
- 904 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 436 Remote Operation (SmartLink)
- 135 Contesting
- 713 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 935 Third-Party Software
