How do I set up PC audio on the Flex 1500 running PowerSDR 2.7.2?
bobebuyer
Member ✭
I'm running a legacy Flex 1500 with Power SDR 2.7.2, and everything works fine including WSJTX for FT8 via VAC. SSB works great through the hand mic and speakers plugged into the 1500, however I cannot find the button I've seen referred to in Power SDR that would allow me to select PC audio as an alternative to the hand mic and the speaker presently connected to the phone jack on the 1500. I wish to be able to configure the 1500 to work from a remote PC, and of course this requires having the 1500 operate using the Power SDR PC's audio. After I get that working, I'll figure out how to access the radio from a different PC on my home network, connecting to the PC that runs Power SDR and bringing in audio perhaps using RemAud. And after that, I'll figure out how to come in from a remote location via VPN. Thanks!!
In the Window of VAC, VAC 1 and click enabled , then you manager the audio through sound card and speaker output became Off.1
Hi bob... I don't have a 1500, but I did a quick search of documentation for PowerSDR. I'm not finding any reference to a PCAudio selection. There IS one in SmartSDR, but so far, I'm not seeing an equivalent in PowerSDR. Maybe I'm just missing it, but....
OK I got it working, to a point. Audio and microphone work on my shack PC, which is great. And using Windows 10 Pro and making my PC a server, I can get remote access to PowerSDR visually, with mouse control. I installed RemAud to make it possible to remote the input and output audio, and I have yet to figure out how to configure that. However I'm making progress!!1
- 398 Community Topics
- 677 The Flea Market
- 190 SmartSDR+
- 195 SmartSDR for Maestro and M models
- 216 DAX
- 391 SmartSDR API
- 87 Aurora
- 331 FLEX-8000 Signature Series
- 987 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 317 Shack Infrastructure
- 222 Networking
- 840 Peripherals & Station Integration
