WSJT-x On 6800M
Hello all,
I am buying an 6400M and want to keep it independent of my PC hence the M version.
Can I connect with a USB cable from the 6400M into the pc like I do with my icom 7300 without installing SmartSDR on my pc?
I would expect that I would still need to download DAX drivers..
Keith
M0PAW
There is no USB connectivity from a Flex to a PC (to an amp or tuner, yes, via CAT or bit/BCD wiring).
The connection to your WSJT-X instance is via Ethernet cable. You WILL need to install and run DAX and CAT to talk to your Flex, but SSDR is not needed (although is certainly handy if your PC is not at your radio desk)
Brilliant thanks that’s all I needed to know.
I did have a 6500 around 8 years ago and stupidly let it go for a 990 but I am now getting a 6400m thanks for you help..
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
