Antenna Genius High SWR Arcing?
Does the Antenna Genius arc or have other issues when used with feedlines with high SWR and voltage? I run high power.
I have three non-resonant doublets fed with open wire feeders into the shack to baluns and then by coax to the antenna tuner. They often have high SWR before they get to the tuner.
With some high SWR situations, there is very high voltage that can do damage. I have had that happen. I can be running 1,200 watts CW.
My question is not on the quality of my antenna system. It is what it is. I am asking if an Antenna Genius can handle the task.
K1ESE
Best Answers
What you are asking is something that is normally tested in a controlled lab environment just to see what the limitations are.
What I can say, is that it isn't the way I would do it is not designed for balanced feeders. When you design a path for RF to follow, there are rules (math/physics) that you need to follow. And, while it doesn't say it on the 403A.com website, it is implied that feedlines and loads should be near 50 ohms.
To get the answer you really want, you will need to reach out to 4O3A. They have a support email address on their web site.
I have replaced some "highly arc damaged" relays in the AG which prevented selecting 80M from one radio. How they were damaged is unknown but the antenna was known to present high SWR, and running 1.5KW. Repair is very difficult with thin circuit board traces and the 8 small pins on each relay.
You should ask 403A as they have their own support email alias. You can find it on their website.
However, I would suspect that if you are not presenting a 50 ohm load to the AG, then results are unpredictable. It is no different than your actual radio.
Your matching transformers should be at the end of the open wire balanced feeders so that you present some closer to what the AG was designed for.
Others may wish to comment as well.
I think I hear you saying, "probably not".
It's unanimous. I will go to 4O3A.
Thanks!
“Results are unpredictable”, IBMs favorite warning.
- 632 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 40 Aurora
- 953 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
