Icom PW-1 remote control
I know ddutil will control the PW-1 but requires a computer at the remote site. I have a 6300 and the usb to serial cable. The goal is to have the radio and PW-1 at a remote site connecting only to the remote wi fi. The flex sends bcd data via the usb cable and the cable is recognized by the flex radio. At this point I am stuck with very limited knowledge.
If anyone knows how to get the data from the flex civ plug I would appreciate it. The PW-1 also has a din plug with band change voltage input. From 0 to 8 volts.
Anybody done this?
In doing the research, I saw they have changed to a new hardware layout, but it still should work just fine.
https://remoteqth.com/wiki/index.php?page=Band+decoder+MK2
This is a bit of a challenge for PW-1 Users. A few have tried to build interfaces but with limited success as the Icom CI-V format is a bit kludgy at times.
According to the documentation, this device from RemoteQTH will take our band data and convert it to CI-V format. I have used their equipment before and it is really well made.
You will have to do a bit of configuring on your own and loading the configuration file to the band decoder. However, when you are done, it will be very reliable.
We don't have a PW-1 to test with and if configuring an Arduino is a bit scary, it isn't impossible to learn or maybe someone near you could help you out.
- Available Inputs
- Serial ASCII
- Icom CIV
- Kenwood CAT (including TS-x50 with TTL inverter add-on
- Yaesu CAT (TRX since 2008
- Yaesu BCD
- Icom ACC voltage
- Outputs
- Remote IP Relay
- need a version with TCP232 ethernet module. NEW
- 14 Relay
- (0,5A/125VAC, 1A/24VDC)
- USB serial ASCII echo
- Yaesu BCD (relay 11-14)
- Icom CIV
- Kenwood CAT
0 - Available Inputs
Thankyou, I will do some reading and research their device. Once again I appreciate the effort to help out.
- 379 Community Topics
- 631 The Flea Market
- 120 SmartSDR+
- 193 DAX
- 39 Aurora
- 947 Maestro
- 924 Genius Products
