FLEX API panadapter antenna select command not working
Can anyone tell me why this API command is rejected by the radio?
C12|display pan s 0x40000001 ant=ANT1
I get this returned:
0x5000002D Bad field
Best Answers
Hi Gary, it took a bit of experimentation, but I figured out:
CD24 | display pan s 0x40000000 rxant=ANT1
This works on panadapter 0 on my 6400. I have not figured out how to set the TX ant. I assume I need a slice param for that.
Hopefully this helps.
Hello Gary,
As Len has pointed out, the SmartSDR API Wiki documentation does not always match the newer versions of software. I am running Version 2 and have found that to be true.
The method I have used to resolve the differences is to transcribe the radios TCP status messages and compare the name/value pairs with the Wiki documentation. Here is a link to my list with one scu, one panafall and one slice receiver:
http://ab9a.net/flex_control/6600_messages.txt
It shows: display -> pan -> 0x40000000 -> rxant=ANT1
This agrees with the name/value pair Len discovered.
This system isn’t fool proof. There are name/value pairs in the list that are not settable there and are report only. And some name/value pairs that are settable there that aren’t in the Wiki documentation ie. slice rit and xit. But, comparing the list, with a little insight into the radio’s architecture:
Ant -> SCU -> Panafall -> Slice Receiver
And some experimentation will usually get you there.
Clay, AB9A
Thanks for the information and it does work with the rxant= command. I thought maybe it was a command format issue as there had to be a way to change antennas. I should have tried various combinations, but also thought maybe someone had already done that and would share their findings as you both did.
I'll keep that list handy and refer to it if I have problems in the future. Thanks for sharing it.
Gary
K6HN
Hi Gary,
Here is how you can set antennas using slice set commands instead of panadapter commands:
CD24 | slice s 0 rxant=ANT2
CD24 | slice s 0 txant=ANT2
Depending on what you are doing, one may be preferrable over the other. In any case, changing the TXANT looks like it needs to be done with the slice set command.
Hi Len,
Thanks for the info, I was aware of those commands. I created a GUI client with a panadapter and it seems to have a separate antenna selection for the pan vs a slice. Maybe it's the way I am doing it, but it's all working well now.
Great to hear! Are you writing code for a controller like an Arduino or Pi or is this a windows app?
Using node-red and these nodes.
Release of node-red-contrib-flexradio nodes v1.1! — FlexRadio Community
Node-red offers simplified programming for us non-skilled programmers. All I really need to know is basic Javascript.
Very cool!
I found another command that isn't working for me.
'slice list'
I am trying to get a list of active slices in the radio.
Hi Gary, that command works. Here is the command and results:
"CD22 | slice list"
R22|0|0 1 | In this case, I have two slices open, 0 and 1.
R22|0|0 | In this case, I only have one slice open, slice 0.
R22|0|| And for completeness sake... No slices are open.
Thanks Len. I must be doing something wrong. I'll look into it.
Hello Gary,
There is another way to get the use status of a slice receiver that’s not explicitly spelled out in the API:
Each slice has an “in_use=0/1” name value pair that it reports over the slice TCP status message.
If you parse and capture the “in_use=“ state, you can query each slice receiver and maintain your own list.
Clay, AB9A
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
