FLEX API panadapter antenna select command not working
K6HN
K6HN Member ✭✭
edited January 2022 in SmartSDR API
Can anyone tell me why this API command is rejected by the radio?
C12|display pan s 0x40000001 ant=ANT1
I get this returned:
0x5000002D Bad field
Best Answers
    Answer ✓
    Hi Gary, it took a bit of experimentation, but I figured out:
    CD24 | display pan s 0x40000000 rxant=ANT1
    This works on panadapter 0 on my 6400. I have not figured out how to set the TX ant. I assume I need a slice param for that.
    Hopefully this helps.
  • Clay
    Clay Member ✭✭
    Answer ✓
    Hello Gary,
    As Len has pointed out, the SmartSDR API Wiki documentation does not always match the newer versions of software. I am running Version 2 and have found that to be true.
    The method I have used to resolve the differences is to transcribe the radios TCP status messages and compare the name/value pairs with the Wiki documentation. Here is a link to my  list with one scu, one panafall and one slice receiver:
    http://ab9a.net/flex_control/6600_messages.txt
    It shows: display -> pan -> 0x40000000 -> rxant=ANT1
    This agrees with the name/value pair Len discovered.
    This system isn’t fool proof. There are name/value pairs in the list that are not settable there and are report only. And some name/value pairs that are settable there that aren’t in the Wiki documentation ie. slice rit and xit. But, comparing the list, with a little insight into the radio’s architecture:
    Ant -> SCU -> Panafall -> Slice Receiver
    And some experimentation will usually get you there.
    Clay, AB9A
  • K6HN
    K6HN Member ✭✭
    Thanks for the information and it does work with the rxant= command. I thought maybe it was a command format issue as there had to be a way to change antennas. I should have tried various combinations, but also thought maybe someone had already done that and would share their findings as you both did.
    I'll keep that list handy and refer to it if I have problems in the future. Thanks for sharing it.
    Gary
    K6HN
    Hi Gary,
    Here is how you can set antennas using slice set commands instead of panadapter commands:
    CD24 | slice s 0 rxant=ANT2
    CD24 | slice s 0 txant=ANT2
    Depending on what you are doing, one may be preferrable over the other. In any case, changing the TXANT looks like it needs to be done with the slice set command.
  • K6HN
    K6HN Member ✭✭
    Hi Len,
    Thanks for the info, I was aware of those commands. I created a GUI client with a panadapter and it seems to have a separate antenna selection for the pan vs a slice. Maybe it's the way I am doing it, but it's all working well now.
    Great to hear! Are you writing code for a controller like an Arduino or Pi or is this a windows app?
  • K6HN
    K6HN Member ✭✭
    Using node-red and these nodes.
    Release of node-red-contrib-flexradio nodes v1.1! — FlexRadio Community
    Node-red offers simplified programming for us non-skilled programmers. All I really need to know is basic Javascript.
    Very cool!
  • K6HN
    K6HN Member ✭✭
    I found another command that isn't working for me.
    'slice list'
    I am trying to get a list of active slices in the radio.
    Hi Gary, that command works. Here is the command and results:
    "CD22 | slice list"
    R22|0|0 1 | In this case, I have two slices open, 0 and 1.
    R22|0|0 | In this case, I only have one slice open, slice 0.
    R22|0|| And for completeness sake... No slices are open.
  • K6HN
    K6HN Member ✭✭
    edited January 2022
    Thanks Len. I must be doing something wrong. I'll look into it.
  • Clay
    Clay Member ✭✭
    Hello Gary,
    There is another way to get the use status of a slice receiver that’s not explicitly spelled out in the API:
    Each slice has an “in_use=0/1” name value pair that it reports over the slice TCP status message.
    If you parse and capture the “in_use=“ state, you can query each slice receiver and maintain your own list.
    Clay, AB9A
