no data transfer via usb port
harrymeertens
Member ✭
have a question I have a loop antenna from ciro mazzoni I have connected the loop tuner via usb of the flex 6400 frequency change should tune the loop automatically but that is not happening it works with my yaesu transceiver but I think the usb port of the flex for some reason no signal to the tuner from the loop how can i check if the usb is working the cable is from flexradio .nl
Harry
Here is a link to the Flex USB Guide. Ensure your USB cable settings are configured as per the guide.
Alan. WA9WUD
https://www.flexradio.com/documentation/usb-cable-interface-guide-pdf/
Also, Yaesu and Flex (Kenwood) CAT protocol are different. If you can change your antenna to use Flex or Kenwood protocol it should work.
- 391 Community Topics
- 665 The Flea Market
- 165 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 304 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 826 Peripherals & Station Integration
- 145 Amateur Radio Interests
