no data transfer via usb port
harrymeertens
Member ✭
have a question I have a loop antenna from ciro mazzoni I have connected the loop tuner via usb of the flex 6400 frequency change should tune the loop automatically but that is not happening it works with my yaesu transceiver but I think the usb port of the flex for some reason no signal to the tuner from the loop how can i check if the usb is working the cable is from flexradio .nl
Harry
Here is a link to the Flex USB Guide. Ensure your USB cable settings are configured as per the guide.
Alan. WA9WUD
https://www.flexradio.com/documentation/usb-cable-interface-guide-pdf/
Also, Yaesu and Flex (Kenwood) CAT protocol are different. If you can change your antenna to use Flex or Kenwood protocol it should work.
