SmartSDR v3.3.29 and the SmartSDR v3.3.29 Release Notes | SmartSDR v2.7.6 and the SmartSDR v2.7.6 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
Transmit Recordings smart sdr for Mac
Good morning from soggy and snowy Oregon. I am running SmartSDR for Mac on a mini M1 Mac that does not have an input device. I can record a track, and when transmitting the input switches to Mac but there is no output as you have experienced. If I change my setting in the Radio Controls to Mac (from BAL or MIC) it will then transmit the recorded audio. You must also go into the settings menu on the 'Recordings' tool and set TX gain to an appropriate (non-zero) setting. I would think that the app switching to Mac as the input device should work the same as manually setting it to Mac but in my initial investigations it isn't working as expected.
W7NGA, Daniel, Seaside Oregon
Which version of SmartSDR for mac are you running? I'm running 2.0.15 and I can record and TX the recording without issues using the recordings tool. DAX does not needs to be enabled to TX recordings.
I too running 2.0.15. I can record fine, and playback, but the playback is not going out no RF. Thanks to Daniel W7NGA, I engaged the mac in the MIC settings...well, it worked, but it came along with a strong hum going out in the RF...so Im back to the drawing board on this one. I must have an errant setting somewhere but I have no idea.
In the 'Recordings' mode audio comes from your laptop and can cause problems if RF finds its way into the computer. I would insure that the recordings are coming thru correctly and then gradually increase power until the hum (possible RF ingress) occurs. If it doesn't occur at low power settings you are probably on the right track and will have to play with physical separation, ferrites, and other mitigation measures.
I will write to Marcus, the SmartSDR for Mac developer, and let him know that we are seeing the problem with audio routing in the recordings mode. I'm also curious how you have determined your signal includes hum (separate receiver, FDX).
W7NGA
Thanks for the reply. The report of a background hum is coming from station listening to my TX recordings. B
I have shared the audio routing issue with Marcus, DL8MRE and will report back. I am able to run full legal limit on AM with the Recordings tool playing a recorded audio track via MAC M1 mini. No issues.
W7NGA
Marcus DL8MRE says the Mac audio routing issue with the Recordings tool is a bug and will be fixed in the next update.
W7NGA
Ah, a bug, well at least for once its not operator error (me). I will await the next update from Marcus. Thanks and 73, Brad
Same problem here, i contacted before a week with Marcus but he told me that there is not a problem from others users.... now i see that there are other users with the same problem
sv3eao
- 18.3K All Categories
- 125 Community Topics
- 2K New Ideas
- 274 The Flea Market
- 6.1K Software
- 5.3K SmartSDR for Windows
- 90 SmartSDR for Maestro and M models
- 201 SmartSDR for Mac
- 185 SmartSDR for iOS
- 179 SmartSDR CAT
- 108 DAX
- 316 SmartSDR API
- 7.8K Radios and Accessories
- 6.3K FLEX-6000 Signature Series
- 625 Maestro
- 29 FlexControl
- 768 FLEX Series (Legacy) Radios
- 393 Genius Products
- 235 Power Genius XL Amplifier
- 140 Tuner Genius XL
- 18 Antenna Genius
- 114 Shack Infrastructure
- 71 Networking
- 196 Remote Operation (SmartLink)
- 87 Contesting
- 290 Peripherals & Station Integration
- 86 Amateur Radio Interests
- 567 Third-Party Software
