Power readings in DIGU on PGXL not showing correctly. It that normal?
Lately, I noticed that when in DIGU mode the PGXL display shows only 1 watt out even though other physical meter show 380 watts. Is that normal or have I set something up incorrectly? When in USB mode everything looks correct.
  • David Decoons, wo2x
    I have not seen that on my PG XL.
    What is the radio TX bandwidth set to?
  • k7rfh.rich
    k7rfh.rich Member ✭✭
    3.3K on USB and 3.0K on DIGU
    what version firmware in amp?
    Does the Windows app show same low power?
    What if you use the tune button? (Steady carrier).
  • k7rfh.rich
    PGXL Utility 3.6.23
    Yes, Win app shows about the same (hard to tell exactly)
    Tune button with amp on show about right power reading on both.
  • Ron Koenig
    Ron Koenig Member ✭✭✭
    ALL Meter readings are Bogus in 3.6.23 It should have never been released... Use an external Watt Meter.
  • NN4X
    NN4X Member
    edited January 2022
    [ Running 3.6.23 FW ]
    When I transmit a carrier on the PGXL, I'm getting 960 watts output indicated on my LP-700, and 323 watts on the PGXL Utility.
    This disparity continues no matter the mode, but am using this as an example using a carrier to avoid the differences between PEP vs. Average power measurements.
    I opened a ticket on this today, and hopefully everyone else experiencing similar issues will do the same.
