PTT not working on a new 6400
KW1DX
I have a new Flex 6400 and PPT does not work with either the supplied microphone or a foot switch. The microphone works fine using VOX or MOX just not with PPT. Since it does not work with a foot switch either I think it must be the radio and not the mic.
Is there a setting that turns on/off the PTT? Any ideas what to try?
Have you checked the tx band settings? There is a setting called "PTT INHIBIT". It is just possible you have this selected, then the rig will not respond to PTT, but will respond to MOX etc.??
73 Mike G4GWH
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsSince you are new, there are a few things that could help out.
- First, I would do a full reset on the radio.
- When you push PTT, so you receive any TX Inhibit messages on SmartSDR?
- Just for fun, can you use an Ohm meter to confirm your foot switch is working
- Can you share a screen shot of SmartSDR?
Thanks for the comments:
- In TX Band Setting none of the bands have PPT Inhibit checked
- Completed a full reset on the radio did not fix the problem
- No TX inhibit messages are displayed when keying the mic
- Checked the foot switch with an Ohm meter and is properly working
- Screen shots are attached0 -
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI have opened a support ticket for you.
This discussion has been closed.
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 115 Aurora
- 353 FLEX-8000 Signature Series
- 981 Genius Products
- 359 Tuner Genius XL
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
- 486 Remote Operation (SmartLink)
- 848 Peripherals & Station Integration
