60 meters on the 6300
N3NER
I just got a new 6300 and sold my Icom. I have used 60 meters in the past and it seems 60 meters is disabled for TX. How can I get this opened up?
I tried all the modes and the TUNE and MOX button stay grayed out, the only mode it does not stay grayed out is CW.0
What is your call or QTH Nick?0
W2NER0
Oh, and my QTH is Hopewell junction NY0
All radios sold in the US have the 60m band enabled. However, you must be within a designated channel in order for TX to be enabled. I suspect your slice is tuned to a frequency that is outside of the 60m channel.1
Tim, i have the same problem i live in canada at 5.370mhz 60m it's not activated
http://www.rac.ca/rac-0-30-mhz-band-plan/0 -
Double check your TX bandwidth. It should be less than 2.8 khz
Cal/N3CAL
3000khz it's ok thank's
So I have the same problem. I have double checked the frequencies, USB, 2.7 width, under 100w and it still doesn't enable. Haven't tried CW but that's not what I want to try 60m with. So, my assumption is I need a ticket open too? Any other suggestions?0
Please post a screen shot of SmartSDR while you are on 60M.
- what VFO frequency?
- Your High and Low pass Mic settings
If your TX doesn't enable, you are somehow 'out of band'.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
