FlexRadio WSJT-X Setup for Mac OSX (Version 0.6)
I wrote a setup document for how to get WSJT-X up and running with Mac OSX computer and a FlexRadio 6xxx SDR.
KG4ASZ
  • Alan
    Alan Member ✭✭✭✭
    Rufus
    Nice document.
    Comment. Suggest you remove Section 2, changing the MacSmartSDR Audio in/out, section. The audio to/from WSJT-X will be via DAX and loopback. In your method, you loose all in/out audio, from the microphone and speakers, when you want to do other modes.
    Let me know if you need help with MLDX.
    Alan. WA9WUD
  • Rufus
    Rufus Member ✭✭
    Good Point. Will update
  • ea3imr
    ea3imr Member
    Hi Rufus,
    I've followed the instructions from the document, step by step.
    Everything's going well, reception, transmission but... after 2 or 3 transmit cicles form wsjt-x, suddenly wsjt-x breaks and I have to cancel and restart wsjt-x.
    I've tested several times and I've ever got the same behaviour.
    I'm using the last wsjt-x stable version: v2.6.1.
    Tomàs. EA3IR
