FlexRadio WSJT-X Setup for Mac OSX (Version 0.6)
Rufus
I wrote a setup document for how to get WSJT-X up and running with Mac OSX computer and a FlexRadio 6xxx SDR.
KG4ASZ
2
Rufus
Nice document.
Comment. Suggest you remove Section 2, changing the MacSmartSDR Audio in/out, section. The audio to/from WSJT-X will be via DAX and loopback. In your method, you loose all in/out audio, from the microphone and speakers, when you want to do other modes.
Let me know if you need help with MLDX.
Alan. WA9WUD
Good Point. Will update
Hi Rufus,
I've followed the instructions from the document, step by step.
Everything's going well, reception, transmission but... after 2 or 3 transmit cicles form wsjt-x, suddenly wsjt-x breaks and I have to cancel and restart wsjt-x.
I've tested several times and I've ever got the same behaviour.
I'm using the last wsjt-x stable version: v2.6.1.
Tomàs. EA3IR0
- 688 The Flea Market
- 105 Aurora
