Flex 6700 not transmitting ssb macros from N1MM
Hi, N1MM connects fine to my flex and have no trouble transmitting CW Macros. However when I transmit an ssb voice macro I see the radio go into transmit, but there is no rf power going out. I can also hear my voice macro calling cq with monitor selected. Anybody have any ideas what I am doing wrong? thanx, stuart
Is VOX turned on? If so, turn it off and see if that makes a difference. https://community.flexradio.com/discussion/comment/19858863#Comment_19858863
Tim K9WX
Do you have DAX configured correctly? The audio output from N1MM must connect to DAX TX Audio, and DAX must be enabled on the slice on the Flex radio. You can check to see if you have audio deflection on the DAX app panel in the TX section, and adjust the level. You should also see audio activity on the Mic level meter on the Flex SmartSDR control panel.
73, Craig KØCF
vox is off, dax receive and xmit is on. Let me try to clarify a little. when I push the macro button, ex. F1, I hear myself transmitting CQ over computer speakers with smart sdr "pc audio" not selected. I get a xmit light on the physical radio. Smart SDR shows a small SWR and no RF Pwr. The waterfall blanks just like a normal transmit with the current panadapter showing a transmitting wave form.
With respect to N1MM all the cw, rtty macros work fine and transmit properly. I'm sure its probably a setting in N1MM but havn't a clue.
In N1MM Config menu, the third choice is Logger+ Audio Setup. Click on that. In the Window that opens, select the second tab at the top, Playback. The first drop down I have set for SO1V / SO2V Single Soundcard.
In the Radio 1 drop down, select DAX Audio TX (FlexRadio Systems).
This should make it work.
73, Craig KØCF
that was a big help, not there yet but a big change. Craig, I set it up exactly as you said,playback set to dax audio tx and message recoring set to dax receive 1. now the message plays silently and not not through my computer. I had never messed with that Audio Setup & monitor. However when I try to play it, it still does not send any rf power out. I Still get the transmit lite and very small swr display. No indication on panadapter now but still see blank lines during transmit on waterfall. The mox lite also lites up during transmit. again no rf power though.
OK GOT IT!!!! You rock! I just had the DAX button not on this time. Setting the audio was the Key.
thank you thank you thank you!
73, stuart
For others, if you follow this document to the letter, it works FB.
It is for all 6000 series radios.
- 390 Community Topics
- 659 The Flea Market
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
